查看: 2261|回复: 0
【SD】BN-3511CQ CP9404.00 [复制链接]
发表于 2011-11-9 08:43:49 |只看该作者 |倒序浏览
Controller marking :  BN-3511CQ CP9404.00
Memory chip marking :  HY27UF(G)082G2M
Memory chip ID :  0xADDA8015
Capacity(Mb) :  256
Variant 1 Author: serviceman [4]
Split by dump (Dump number 8)
76543210
Change order (New order 7,6,5,4,3,2,1,0)
Block Size256
Mask0xFF00
Full Block? (default)
Page size 528
Sector size 528
0-172;176-172;352-168;520-8;172-4;348-4;
GMT+8, 2026-7-13 02:53 , Processed in 0.101997 second(s), 13 queries .
