查看: 2622|回复: 0
【SD】PS8005-A UT0845BB P5CP5.13 [复制链接]
发表于 2011-11-9 11:59:14 |只看该作者 |倒序浏览
Controller marking :  PS8005-A UT0845BB P5CP5.13
Memory chip marking :  JS29F32G08FAMC1
Memory chip ID :  0x89D7D53E
Capacity(Mb) :  16384
Variant 1 Author: ravishankar12 [52]
1302
Split by dump (Dump number 2)
Mask0x0FFF
Full BlockYes
GMT+8, 2026-7-12 19:47 , Processed in 0.092947 second(s), 13 queries .
