查看: 2472|回复: 0
【SD】SM266BF AB H096782 [复制链接]
发表于 2011-11-9 11:20:08 |只看该作者 |倒序浏览
Controller marking :  SM266BF AB H096782
Memory chip marking :  K9G8G08U0M
Memory chip ID :  0xECD31425
Capacity(Mb) :  1024
Variant 1 Author: vip [102]
Block Number Type 2 [SM32xx]
Use Add-insNo
Full blocksNo
GMT+8, 2026-7-12 20:45 , Processed in 0.096338 second(s), 13 queries .
