查看: 2364|回复: 0
【SD】SK6612 AARC A0624 [复制链接]
发表于 2011-11-9 09:22:53 |只看该作者 |倒序浏览
Controller marking :  SK6612 AARC A0624
Memory chip ID :  0xADDC8095
0213
Change order (New order 0,2,1,3)
Change order (New order 1,0)
Marker Pos522
Block Size512
Full Block? (default)
Page size 4224
Sector size 570
0-512;512-10;4176-48;
522-512;1034-10;4176-48;
1044-512;1556-10;4176-48;
1566-512;2078-10;4176-48;
2088-512;2600-10;4176-48;
2610-512;3122-10;4176-48;
3132-512;3644-10;4176-48;
3654-512;4166-10;4176-48;
GMT+8, 2026-7-13 01:43 , Processed in 0.097632 second(s), 13 queries .
