查看: 2461|回复: 0
【SD】Glued PCB Unknown SA PS800x [复制链接]
发表于 2011-11-9 11:59:12 |只看该作者 |倒序浏览
Controller marking :  Glued PCB Unknown SA PS800x
Memory chip marking :  HY27UA08T2MTR
Memory chip ID :  0xADD514B6
Variant 1 Author: Sheremetov [67]
Mask0x0FFF
Full BlockNo
GMT+8, 2026-7-12 18:12 , Processed in 0.099531 second(s), 13 queries .
