查看: 3089|回复: 0
【SD】PS8005-A UT083588 P53L2.13 [复制链接]
发表于 2011-11-9 12:38:17 |只看该作者 |倒序浏览
Controller marking :  PS8005-A UT083588 P53L2.13
Memory chip ID :  0x89D5943E
Variant 1 Author: Karol [204]
Full Block? (default)
Page size 538
Sector size 538
0-512;512-26;
GMT+8, 2026-7-12 17:24 , Processed in 0.090121 second(s), 13 queries .
