查看: 2599|回复: 0
【SD】PS8005-A UT082788 P5264.13 [复制链接]
发表于 2011-11-9 11:59:11 |只看该作者 |倒序浏览
Controller marking :  PS8005-A UT082788 P5264.13
Memory chip ID :  0x89D5943E
Variant 1 Author: Karol [204]
Full Block? (default)
Page size 538
Sector size 538
0-512;512-26;
GMT+8, 2026-7-12 20:31 , Processed in 0.099988 second(s), 13 queries .
