查看: 3128|回复: 0
【SD】SD (Glued) [复制链接]
发表于 2011-11-9 11:59:10 |只看该作者 |倒序浏览
Controller marking :  SD (Glued)
Memory chip marking :  TC58NVG4D1DTG00
Memory chip ID :  0x98D594BA
Special action (description in comment)
Split by dump (Dump number 2)
Marker Pos516
Mask0x07FF
Page size 4304
Sector size 538
0-512;4250-8;512-18;
534-512;4250-8;1046-18;
1068-512;4250-8;1580-18;
1602-512;4250-8;2114-18;
2136-512;4250-8;2648-18;
2670-512;4250-8;3182-18;
3204-512;4250-8;3716-18;
3738-512;4250-8;4258-18;
GMT+8, 2026-7-12 19:01 , Processed in 0.185824 second(s), 13 queries .
