查看: 2263|回复: 0
【SD】Glued PCB SDC801 [复制链接]
发表于 2011-11-9 09:22:50 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SDC801
Memory chip marking :  HY27UG088G2M
Memory chip ID :  0xADD3C195
Variant 1 Author: Karol [204]
Parts of memory chips (2)
Block Size256
Even BlockNo
GMT+8, 2026-7-13 02:36 , Processed in 0.113317 second(s), 13 queries .
