查看: 2254|回复: 0
【SD】SM268BF BB QS0046.1 0807 T7D [复制链接]
发表于 2011-11-9 09:22:50 |只看该作者 |倒序浏览
Controller marking :  SM268BF BB QS0046.1 0807 T7D
Memory chip ID :  0xECD55525
Variant 1 Author: Karol [204]
Translator Type 19 [SM267BB]
Variant 2 Author: Karol [204]
Block Number Type 2 [SM32xx]
Use Add-insNo
Full blocksNo
GMT+8, 2026-7-13 02:36 , Processed in 0.108622 second(s), 13 queries .
