查看: 2196|回复: 0
【SD】PS800x [noname] [复制链接]
发表于 2011-11-9 08:43:44 |只看该作者 |倒序浏览
Controller marking :  PS800x [noname]
Memory chip ID :  0xADD314A5
Variant 1 Author: Ddr [1]
Parts of memory chips (2)
Block Rotate (Block Size 1024,Marker Pos 512,Id 1234,Mask 0x0FF0,Small Block 16)
Mask0x0FFF
Full Block? (default)
GMT+8, 2026-7-13 02:10 , Processed in 0.099337 second(s), 13 queries .
