查看: 2394|回复: 0
【SD】SK6612 ACRC A0642 B58476-1 [复制链接]
发表于 2011-11-9 08:43:43 |只看该作者 |倒序浏览
Controller marking :  SK6612 ACRC A0642 B58476-1
Memory chip marking :  HY27UV088G5
Memory chip ID :  0xADD38525
Variant 1 Author: Karol [204]
Parts of memory chips (2)
Block Size512
Full Block? (default)
Page size 2112
Sector size 546
0-512;2088-24;512-10;
522-512;2088-24;1034-10;
1044-512;2088-24;1556-10;
1566-512;2088-24;2078-10;
GMT+8, 2026-7-13 02:53 , Processed in 0.104296 second(s), 13 queries .
