查看: 2467|回复: 0
【SD】SM264AF AG [复制链接]
发表于 2011-11-9 08:43:42 |只看该作者 |倒序浏览
Controller marking :  SM264AF AG
Memory chip marking :  K9F8G08
Memory chip ID :  0xECD310A6
Capacity(Mb) :  1024
Variant 1 Author: Karol [204]
Block Number Type 2 [SM32xx]
Use Add-insNo
Full blocksNo
GMT+8, 2026-7-13 02:15 , Processed in 0.237614 second(s), 13 queries .
