查看: 2341|回复: 0
【USB Flash】Glued Kingston SDHC class 6 1 chip 2 part [复制链接]
发表于 2011-11-9 09:22:37 |只看该作者 |倒序浏览
Controller marking :  Glued Kingston SDHC class 6 1 chip 2 part
Memory chip marking :  29F64G08CAMD2
Memory chip ID :  0x89D7943E
Change order (New order 1,0)
Mask0x0FFF
Page size 4320
Sector size 528
0-512;1024-16;
512-512;1024-16;
1074-512;1024-16;
1586-512;1024-16;
2144-512;1024-16;
2656-512;1024-16;
3214-512;1024-16;
3726-512;1024-16;
GMT+8, 2026-7-13 01:44 , Processed in 0.095931 second(s), 13 queries .
