查看: 2322|回复: 0
【USB Flash】PS800X XXXX [复制链接]
发表于 2011-11-9 08:43:14 |只看该作者 |倒序浏览
Controller marking :  PS800X XXXX
Memory chip marking :  MT29F8G08MAA
Memory chip ID :  0x2CD394A5
Capacity(Mb) :  1024
Block Rotate (Block Size 0,Marker Pos 0,Id 1234,Mask 0x0000,Small Block 0)
Translator Type 35 [Phison PS800x]
GMT+8, 2026-7-13 01:24 , Processed in 0.098094 second(s), 13 queries .
