查看: 3218|回复: 0
【USB Flash】PS2231 0729 Verbatim USB stick (rubber coated) [复制链接]
发表于 2011-11-9 11:58:35 |只看该作者 |倒序浏览
Controller marking :  PS2231 0729 Verbatim USB stick (rubber coated)
Memory chip marking :  K9G8G08U0M
Memory chip ID :  0xECD31425
Capacity(Mb) :  1024
Mask0x0FFF
GMT+8, 2026-8-26 23:04 , Processed in 0.099974 second(s), 13 queries .
