查看: 3065|回复: 0
【USB Flash】UT163-Q4 APDT010 0706 A18 [复制链接]
发表于 2011-11-9 12:37:21 |只看该作者 |倒序浏览
Controller marking :  UT163-Q4 APDT010 0706 A18
Memory chip ID :  0xECD55525
Variant 1 Author: tesweb [5]
Change order (New order 1,0)
Even BlockYes
GMT+8, 2026-7-12 19:00 , Processed in 0.129338 second(s), 13 queries .
