查看: 2778|回复: 0
【USB Flash】AU6982-E41-GHL [复制链接]
发表于 2011-11-9 12:37:13 |只看该作者 |倒序浏览
Controller marking :  AU6982-E41-GHL
Memory chip ID :  0xECD755B6
Variant 1 Author: ravishankar12 [52]
Copy in preparation results
Translator Type 2 [AU6389,AU6980,AU6981,AU6982]
Bank Size
Block Size? (default)
Add-Ins Size? (default)
Add-Ins Offset? (default)
GMT+8, 2026-7-12 17:24 , Processed in 0.101048 second(s), 13 queries .
