查看: 3096|回复: 0
【USB Flash】AU6986EAS-KL [复制链接]
发表于 2011-11-9 12:37:13 |只看该作者 |倒序浏览
Controller marking :  AU6986EAS-KL
Number of memory chips :  8
Memory chip ID :  0xECD755B6
Capacity(Mb) :  65536
Variant 1 Author: pad-dataservice [17]
Initial memory chips (8)
0123456789101112131415
Parts of memory chips (16)
Copy in preparation results
5713460291113158101214
Change order (New order 5,7,1,3,4,6,0,2,9,11,13,15,8,10,12,14)
1023
Change order (New order 1,0,2,3)
Marker Pos513
Block Size8192
Mask0x0FFF
GMT+8, 2026-7-12 19:50 , Processed in 0.101163 second(s), 13 queries .
