查看: 2310|回复: 0
【USB Flash】AU6983 A51-GHL-GR H28349-0 0810T85J [复制链接]
发表于 2011-11-9 08:42:38 |只看该作者 |倒序浏览
Controller marking :  AU6983 A51-GHL-GR H28349-0 0810T85J
Number of memory chips :  4
Memory chip marking :  FBNL52AHCK3WG
Memory chip ID :  0x2CD5943E
Variant 1 Author: petkus [6]
Initial memory chips (4)
3102
Change order (New order 3,1,0,2)
Change order (New order 1,0)
Translator Type 13 [AU6983,AU6986]
Bank Size1024
Add-Ins Size32
Add-Ins Offset8
Page size 8608
Sector size 536
0-512;512-24;
536-512;1048-24;
1072-512;1584-24;
1608-512;2120-24;
2144-512;2656-24;
2680-512;3192-24;
3216-512;3728-24;
3752-512;4264-24;
4288-512;4800-24;
4824-512;5336-24;
5360-512;5872-24;
5896-512;6408-24;
6432-512;6944-24;
6968-512;7480-24;
7504-512;8016-24;
8040-512;8552-24;
GMT+8, 2026-7-13 01:25 , Processed in 0.093423 second(s), 14 queries .
