查看: 2427|回复: 0
【USB Flash】kingston SD [复制链接]
发表于 2011-11-9 10:00:31 |只看该作者 |倒序浏览
Controller marking :  kingston SD
Memory chip marking :  TH58NVG4D4CTG00
Memory chip ID :  0x98D585A5
Variant 1 Author: EDILTON [14]
Copy in preparation results
Split by dump (Dump number 2)
Block Number Type 4 [Kingston SD]
GMT+8, 2026-7-13 00:04 , Processed in 0.102229 second(s), 13 queries .
