查看: 2480|回复: 0
【USB Flash】SM324QFBB A67433 0636 [复制链接]
发表于 2011-11-9 08:50:36 |只看该作者 |倒序浏览
Controller marking :  SM324QFBB A67433 0636
Memory chip marking :  HY27UU(T)084G2M
Memory chip ID :  0xADDC8425
Capacity(Mb) :  512
Variant 1 Author: docentoroker [4]
Block Number Type 2 [SM32xx]
Block Size512
Use Add-insNo
Full blocksNo
GMT+8, 2026-7-13 03:47 , Processed in 0.100549 second(s), 13 queries .
