查看: 2467|回复: 0
【USB Flash】UT161-T6G PCA108 0626JA A2 [复制链接]
发表于 2011-11-9 08:50:32 |只看该作者 |倒序浏览
Controller marking :  UT161-T6G PCA108 0626JA A2
Memory chip ID :  0xADDC8095
Variant 1 Author: vich [3]
Block Size256
Even BlockNo
Variant 2 Author: vich [3]
1302
Block Size256
Even BlockNo
GMT+8, 2026-7-13 02:10 , Processed in 0.097689 second(s), 13 queries .
