查看: 2438|回复: 0
【USB Flash】UT163-L6 [复制链接]
发表于 2011-11-9 08:11:25 |只看该作者 |倒序浏览
Controller marking :  UT163-L6
Number of parts :  4
Memory chip marking :  HY27UU08AG2M
Memory chip ID :  0xADD555A5
Even BlockYes
GMT+8, 2026-7-13 00:33 , Processed in 0.091912 second(s), 13 queries .
