查看: 2997|回复: 0
【USB Flash】SM3211T BC [复制链接]
发表于 2011-11-9 07:32:19 |只看该作者 |倒序浏览
Controller marking :  SM3211T BC
Memory chip marking :  TC58NVG4D2ETG
Memory chip ID :  0x98D59432
Split by dump (Dump number 8)
02461357
Change order (New order 0,2,4,6,1,3,5,7)
Mask0x03FF
Page size 8576
Sector size 528
0-512;512-16;
528-512;512-16;
1056-512;512-16;
1584-512;512-16;
2112-512;512-16;
2640-512;512-16;
3168-512;512-16;
3696-512;512-16;
4224-512;512-16;
4752-512;512-16;
5280-512;512-16;
5808-512;512-16;
6336-512;512-16;
6864-512;512-16;
7392-512;512-16;
7920-512;512-16;
GMT+8, 2026-7-12 23:00 , Processed in 0.099378 second(s), 13 queries .
