查看: 2632|回复: 0
【USB Flash】AU6984 A53-MHL-GR A96200-J 0816T [复制链接]
发表于 2011-11-9 10:08:38 |只看该作者 |倒序浏览
Controller marking :  AU6984 A53-MHL-GR A96200-J 0816T
Memory chip marking :  HY27UG088G5B
Memory chip ID :  0xADDC1095
Variant 1 Author: l32 [63]
1302
Translator Type 12 [AU6984]
Bank Size1024
Add-Ins Size32
Add-Ins Offset8
GMT+8, 2026-7-12 23:15 , Processed in 0.102817 second(s), 13 queries .
