查看: 2957|回复: 0
【USB Flash】M5651 A1 0439 TS05 XCM75560000D [复制链接]
发表于 2011-11-9 10:08:34 |只看该作者 |倒序浏览
Controller marking :  M5651 A1 0439 TS05 XCM75560000D
Memory chip marking :  K9F1G08U0M(A)/(B)
Memory chip ID :  0xECF18015
Capacity(Mb) :  256
Variant 1 Author: GrafCom [1]
Change order (New order 1,0)
Marker Pos513
Block Size512
Even BlockNo
Page size 4224
Sector size 522
0-512;2060-10;
512-512;2070-10;
1024-512;2092-10;
1536-512;2102-10;
2112-512;4172-10;
2624-512;4182-10;
3136-512;4204-10;
3648-512;4214-10;
GMT+8, 2026-7-12 23:15 , Processed in 0.105203 second(s), 14 queries .
