查看: 2399|回复: 0
【USB Flash】Apacer-SD [复制链接]
发表于 2011-11-9 08:50:10 |只看该作者 |倒序浏览
Controller marking :  Apacer-SD
Memory chip ID :  0xECD514B6
Variant 1 Author: Baizhen [11]
Marker Pos515
ID3412
Full BlockYES
GMT+8, 2026-7-13 02:15 , Processed in 0.104997 second(s), 14 queries .
