查看: 2489|回复: 0
【USB Flash】Glued Kingston SD Memory Card [复制链接]
发表于 2011-11-9 09:29:15 |只看该作者 |倒序浏览
Controller marking :  Glued Kingston SD Memory Card
Memory chip marking :  TC58NVG2D4BFT00
Memory chip ID :  0x98DC84A5
Capacity(Mb) :  512
Variant 1 Author: Gefund-IT [7]
Copy in preparation results
Block Size512
GMT+8, 2026-7-13 02:02 , Processed in 0.103063 second(s), 13 queries .
