查看: 2612|回复: 0
【USB Flash】UT163-L6 APD0098 0715 A1B [复制链接]
发表于 2011-11-9 07:32:00 |只看该作者 |倒序浏览
Controller marking :  UT163-L6 APD0098 0715 A1B
Number of memory chips :  4
Memory chip ID :  0xECD55525
Capacity(Mb) :  16384
Variant 1 Author: zeroalpha [12]
Initial memory chips (4)
Parts of memory chips (8)
2301
Change order (New order 2,3,0,1)
Even BlockYes
GMT+8, 2026-7-12 21:37 , Processed in 0.095759 second(s), 13 queries .
