查看: 2404|回复: 0
【USB Flash】Unknown Glued (blue & yellow kodak sd) [复制链接]
发表于 2011-11-9 08:50:09 |只看该作者 |倒序浏览
Controller marking :  Unknown Glued (blue & yellow kodak sd)
Memory chip marking :  K9K8G08U0M
Memory chip ID :  0xECD35195
Parts of memory chips (2)
Block Number Type 2 [SM32xx]
Block Size512
Use Add-insNo
Full blocksNo
GMT+8, 2026-7-13 02:15 , Processed in 0.104407 second(s), 13 queries .
