查看: 2446|回复: 0
【USB Flash】UT163 [复制链接]
发表于 2011-11-9 08:11:00 |只看该作者 |倒序浏览
Controller marking :  UT163
Memory chip marking :  K9L8G08U0A/M
Memory chip ID :  0xECD35525
Variant 1 Author: Wolfsschanze [7]
Change order (New order 1,0)
Even BlockYes
GMT+8, 2026-7-13 00:35 , Processed in 0.092696 second(s), 13 queries .
