查看: 2375|回复: 0
【USB Flash】SM324QF BB (KE METHOD) [复制链接]
发表于 2011-11-9 08:50:01 |只看该作者 |倒序浏览
Controller marking :  SM324QF BB (KE METHOD)
Memory chip marking :  HY27UV088G5
Memory chip ID :  0xADD38525
Parts of memory chips (2)
Join by block for pairs (Block Size 262144)
Marker Pos515
Block Size512
ID3412
GMT+8, 2026-7-13 02:15 , Processed in 0.099697 second(s), 13 queries .
