查看: 2583|回复: 0
【USB Flash】SM3252Q [复制链接]
发表于 2011-11-9 10:47:15 |只看该作者 |倒序浏览
Controller marking :  SM3252Q
Memory chip marking :  JS29F32G08ACMD1
Memory chip ID :  0x89680446
Variant 1 Author: Baizhen [11]
Copy in preparation results
Change order (New order 1,0)
Mask0x03FF
Full BlockYES
Page size 8640
Sector size 528
0-512;512-16;
540-512;512-16;
1080-512;512-16;
1618-512;512-16;
2156-512;512-16;
2694-512;512-16;
3232-512;512-16;
3770-512;512-16;
4308-512;512-16;
4846-512;512-16;
5384-512;512-16;
5922-512;512-16;
6460-512;512-16;
6998-512;512-16;
7536-512;512-16;
8074-512;512-16;
GMT+8, 2026-7-12 22:21 , Processed in 0.109935 second(s), 13 queries .
