查看: 2938|回复: 0
【USB Flash】UT161-T6G PCE032 0627JA A2 [复制链接]
发表于 2011-11-9 06:52:28 |只看该作者 |倒序浏览
Controller marking :  UT161-T6G PCE032 0627JA A2
Memory chip marking :  K9F4G08U0M
Memory chip ID :  0xECDC1095
Capacity(Mb) :  1024
Variant 1 Author: momentus [32]
Even BlockYes
GMT+8, 2026-7-12 20:45 , Processed in 0.107751 second(s), 14 queries .
