查看: 2368|回复: 0
【USB Flash】UT163-L6 [复制链接]
发表于 2011-11-9 07:31:03 |只看该作者 |倒序浏览
Controller marking :  UT163-L6
Memory chip ID :  0xADDC8095
Variant 1 Author: italianrecovery [11]
Block Size512
Even BlockYes
GMT+8, 2026-7-12 21:27 , Processed in 0.100285 second(s), 13 queries .
