查看: 2430|回复: 0
【USB Flash】SM324QF BC [复制链接]
发表于 2011-11-9 09:28:18 |只看该作者 |倒序浏览
Controller marking :  SM324QF BC
Number of parts :  4
Memory chip ID :  0xECD55525
Capacity(Mb) :  16384
Variant 1 Author: vitruss [4]
Parts of memory chips (8)
0123456789101112131415
13570246
Change order (New order 1,3,5,7,0,2,4,6)
Split by dump (Dump number 4)
0246135781012149111315
Change order (New order 0,2,4,6,1,3,5,7,8,10,12,14,9,11,13,15)
Translator Type 7 [SM324QF BC]
GMT+8, 2026-7-13 01:43 , Processed in 0.104140 second(s), 14 queries .
