查看: 2277|回复: 0
【USB Flash】SK6211 [复制链接]
发表于 2011-11-9 09:28:17 |只看该作者 |倒序浏览
Controller marking :  SK6211
Memory chip marking :  29F64G08CAMD2
Memory chip ID :  0x89D7943E
Variant 1 Author: vitruss [4]
Parts of memory chips (8)
0123456789101112131415
13570246
Change order (New order 1,3,5,7,0,2,4,6)
Split by dump (Dump number 4)
0246135781012149111315
Change order (New order 0,2,4,6,1,3,5,7,8,10,12,14,9,11,13,15)
Translator Type 7 [SM324QF BC]
GMT+8, 2026-7-13 01:44 , Processed in 0.096129 second(s), 13 queries .
