查看: 2619|回复: 0
【USB Flash】AU6984-A52 [复制链接]
发表于 2011-11-9 06:51:44 |只看该作者 |倒序浏览
Controller marking :  AU6984-A52
Memory chip ID :  0xECD755B6
Capacity(Mb) :  16384
Variant 1 Author: ravishankar12 [52]
1302
Translator Type 12 [AU6984]
Bank Size1024
Block Size8192
Add-Ins Size64
Add-Ins Offset8
GMT+8, 2026-7-12 19:49 , Processed in 0.103242 second(s), 13 queries .
