查看: 2370|回复: 0
【USB Flash】SM324QF BC A97300 [复制链接]
发表于 2011-11-9 08:09:48 |只看该作者 |倒序浏览
Controller marking :  SM324QF BC A97300
Memory chip ID :  0xADD314A5
Change order (New order 1,0)
Split by dump (Dump number 2)
0213
Change order (New order 0,2,1,3)
Translator Type 7 [SM324QF BC]
GMT+8, 2026-7-12 23:54 , Processed in 0.094500 second(s), 13 queries .
