查看: 6306|回复: 1
PC3000FLASH 执行导入外部编程器读取的DUMP文件 [复制链接]
发表于 2011-8-13 17:56:02 |只看该作者 |倒序浏览
PC-3000FLASH 执行导入外部编程器读取的DUMP文件
如何使用 从其它的编程器读取的存储器芯片的DUMP文件
英文原文
Reference information about hardware-software tool for Data Recovery from SSD and Flash memory storage devices.
All questions about PC-3000 Flash SSD Ed. here.
When you read memory chip in PC-3000 Flash reader its raw image is stored into "dmp" file (you can find this file in folder of task) sector by sector.
Reared creates the dump of chip in accordance with memory chip parameters (reading algorithm, page size, capacity, etc).
As far as we know all readers/programmers read chips by this algorithm.
Hence you can create task in PC-3000 Flash using dumps read via other readers.
All you need is:
- dump file xxx.dmp (or just rename xxx.bin to xxx.dmp)
- number of physical NAND chips
- memory chip ID or marking
Dump file is the sector-by-sector copy of the memory chip.
You need to know memory chip marking or ID because you should have memory chip parameters while dump loading.
Here's how you can create a task using dump file.
1. Create task, source - PC-3000 Flash
2. Select number of NAND chips
3. Enter total capacity of flash drive manually
4. If number of NAND chips is same as number of dumps then skip step 5
5. Click on first chip and add part (if number of dumps and NAND chips is different.)
6. Click on first chip then select option "Load from file"
7. In the field "File" select path to dmp file
8. In the field "Memory chip" select your chip from database
9. Apply. Dump is linked to task now.
10. Perform same operations to second and other chips.
Now all chips are "read" and you can continue analysis.
原文翻译 军达成技术总监
如何使用从其它的编程器读取的存储器芯片的DUMP或BIN(转储文件)
硬件SSD和闪存的存储设备的数据恢复软件工具的参考信息。
关于PC - 3000闪存SSD ED的所有问题。在这里。
当你读到内存芯片在PC - 3000闪存读者“的dmp”文件(任务文件夹中你可以找到这个文件在任务的文件夹) 扇区由扇区。
PC3000FLASH创建根据内存芯片参数芯片的转储(读算法,页面大小,容量,等)。
据我们所知,所有的读者/程序员阅读该算法的芯片。
因此,你可以在PC - 3000闪存使用通过其他读者阅读的转储创建任务。
所有你需要的是:
- 转储文件xxx.dmp(或只是重命名xxx.bin到xxx.dmp)
- 物理NAND芯片
- 内存芯片编号或标记
转储文件的内存芯片扇区由扇区的副本。
您需要知道内存芯片的标识或编号,因为你应该有内存芯片的参数,同时转储装载。
这里是你如何使用转储文件可以创建一个任务。
1。创建任务,来源 - PC - 3000FLASH
2。 选择NAND芯片的数量
3。手动输入闪存芯片总容量
4。如果NAND芯片的数量是相同的DUMPS 的数量,则跳过步骤5
5。点击的第一个芯片和添加部分(如果DUMP 的数量 和NAND芯片的数量是不同的。)
6。点击第一个芯片,然后选择“从文件加载”
7。点击“File”选择dmp文件的路径
8。点击"Memory chip" 从数据库中选择你的芯片
9。应用。DUMP是链接到现在的任务。
10。执行相同的操作,第二和其他芯片。
现在所有的芯片都是“读”,你可以继续分析
    发表于 2011-8-13 19:07:25 |只看该作者
    厉害呀,不错
    GMT+8, 2026-7-27 03:27 , Processed in 1.306621 second(s), 13 queries .
