查看: 2351|回复: 0
【USB Flash】UT163-QF4 APDO095 [复制链接]
发表于 2011-11-9 10:45:57 |只看该作者 |倒序浏览
Controller marking :  UT163-QF4 APDO095
Memory chip ID :  0xECD55525
Variant 1 Author: vich [3]
1302
Even BlockYes
GMT+8, 2026-7-12 23:00 , Processed in 0.097106 second(s), 13 queries .
