查看: 2305|回复: 0
【USB Flash】AU6986 B52-JHL-GR E296551F [复制链接]
发表于 2011-11-9 10:06:51 |只看该作者 |倒序浏览
Controller marking :  AU6986 B52-JHL-GR E296551F
Memory chip ID :  0xECD755B6
Capacity(Mb) :  16384
1302
Translator Type 13 [AU6983,AU6986]
Bank Size1024
Block Size8192
Add-Ins Size64
Add-Ins Offset8
GMT+8, 2026-7-12 23:48 , Processed in 0.098405 second(s), 13 queries .
