查看: 3040|回复: 0
【USB Flash】AU6986 058-GHL-06 A697470 [复制链接]
发表于 2011-11-9 05:59:01 |只看该作者 |倒序浏览
Controller marking :  AU6986 058-GHL-06 A697470
Memory chip ID :  0xECD514B6
Variant 1 Author: Vikas [19]
Translator Type 13 [AU6983,AU6986]
Bank Size
Block Size? (default)
Add-Ins Size? (default)
Add-Ins Offset? (default)
GMT+8, 2026-8-26 23:41 , Processed in 0.102713 second(s), 13 queries .
