查看: 2338|回复: 0
【USB Flash】PS2136CF-G UT0705 AJ1CR2 [复制链接]
发表于 2011-11-9 07:56:09 |只看该作者 |倒序浏览
Controller marking :  PS2136CF-G UT0705 AJ1CR2
Memory chip marking :  K9HBG08U1M
Memory chip ID :  0xECD55525
Variant 1 Author: l32 [63]
Parts of memory chips (2)
Even BlockNo
GMT+8, 2026-7-12 23:06 , Processed in 0.128398 second(s), 13 queries .
