查看: 2404|回复: 0
【USB Flash】UT163-L6 APD0028 0706 A18 [复制链接]
发表于 2011-11-9 07:56:07 |只看该作者 |倒序浏览
Controller marking :  UT163-L6 APD0028 0706 A18
Memory chip marking :  HY27UG088G5M
Memory chip ID :  0xADDC8095
1302
Block Size512
Even BlockNo
GMT+8, 2026-7-12 23:06 , Processed in 0.117838 second(s), 13 queries .
