查看: 2417|回复: 0
【USB Flash】SK6211 [复制链接]
发表于 2011-11-9 07:17:02 |只看该作者 |倒序浏览
Controller marking :  SK6211
Memory chip marking :  29F64G08CAMD2
Memory chip ID :  0x89D7943E
Capacity(Mb) :  16384
Variant 1 Author: AoD [9]
1203
Change order (New order 1,2,0,3)
Translator Type 15 [SK6211]
GMT+8, 2026-7-12 19:54 , Processed in 0.100109 second(s), 13 queries .
