查看: 2743|回复: 0
【USB Flash】UT163-L6 APD0015 0705 A1B [复制链接]
发表于 2011-11-9 06:37:52 |只看该作者 |倒序浏览
Controller marking :  UT163-L6 APD0015 0705 A1B
Memory chip ID :  0xECD55525
Variant 1 Author: vip [102]
Parts of memory chips (2)
Even BlockYes
GMT+8, 2026-8-26 23:41 , Processed in 0.181236 second(s), 13 queries .
