查看: 2362|回复: 0
【USB Flash】PL-2518 LF06086A [复制链接]
发表于 2011-11-9 08:35:00 |只看该作者 |倒序浏览
Controller marking :  PL-2518 LF06086A
Memory chip marking :  K9K4G08U0M
Memory chip ID :  0xECDCC115
Capacity(Mb) :  1024
Variant 1 Author: DimmCo [4]
Change order (New order 1,0)
Marker Pos518
Block Size512
Even BlockNo
GMT+8, 2026-7-13 01:16 , Processed in 0.091687 second(s), 13 queries .
