查看: 2289|回复: 0
【USB Flash】SM321QF CC A91833 [复制链接]
发表于 2011-11-9 07:55:40 |只看该作者 |倒序浏览
Controller marking :  SM321QF CC A91833
Memory chip ID :  0xADD314A5
Variant 1 Author: d43 [99]
3201
Change order (New order 3,2,0,1)
Change order (New order 1,0)
Translator Type 9 [SM325QF AB]
GMT+8, 2026-7-12 23:00 , Processed in 0.101564 second(s), 13 queries .
